Agilex 7 CTM-AGF-014-R24C Material Data Table
We use Autodesk CFD for our thermal analysis, so we need a STEP file of the mechanical assembly with thermal material properties we can assign to the parts. Intel provides this table with the thermal model, but it is missing specific heat capacity and material density which we need to simulate an accurate die temperature.
- AqidAyman_Altera
Can you help to provide where did you get the table?
- AqidAyman_Altera
I wish to follow up with you. Any updates on this? I can help to check with the internal team if you can explain to me which docs you are referring to.
- AqidAyman_Altera
I have found a download link for CTM model in ECXML, PDML, TZR and Step format for AGF 014R24C Device, but you will need to have CNDA and verified MyIntel account to download this file. Refer below link:
Aqid
- AqidAyman_Altera
I hope the previous response was sufficient to help you proceed. As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
