Agilex 5 reconfigurable PLL - emif
Hi Lorenz,
For your issue, are you using the HSIO or HVIO I/O PLL block type?
we are using the calbus and EMIF calibration IP to reconfigure the PLL. Thus according to the Agilex 5 Clocking and PLL user guide, this shoud result in a HSIO I/O PLL block type.
Thank you for your help.
Kind regards,
Lenz
- AqidAyman_Altera4 months ago
Hi Lenz,
The minimum supported phase shift step is fixed by the VCO frequency (e.g., at 1 GHz VCO, the step is 125 ps). If the requested phase shift (e.g., 100 ps) does not align with this step size, the PLL cannot accurately deliver it.
When multiple shifts are performed, quantization and rounding errors can accumulate, leading to some shifts being much larger than intended (i.e., the “occasional large jump” that you observed).
Aqid
