ggoverdh's avatar
ggoverdh
1 month ago
Agilex 5 E-Series 065B Premium Dev Kit - is FPGA_3V3_SDA/SCL driven by an HPS I2C controller?
Board: Agilex 5 E-Series 065B Premium Dev Kit (A5ED065BB32A)
In the schematic, FPGA_3V3_SDA/SCL (U402 MAC EEPROM at 0x56/0x5E, QSFP1/2 at 0x50) goes to Bank 5A HVIO pins (page 17), not to the dedicated HPS_IOA/IOB I2C pins (page 12).
So my understanding is that an HPS I2C controller can drive this bus only if it is routed to the FPGA fabric in the HPS IP, or if a soft I2C master drives it.
Questions:
1. Is that correct, and does the kit's reference design connect an HPS I2C or a soft I2C IP to these pins?
2. How do I confirm which controller drives these pins in Quartus Prime software and at runtime in Linux?
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    Please refer to my answer below:
    <ANS> The dev kit schematic confirms FPGA_3V3_SCL/SDA is the "QSFP1, QSFP2, and EEPROM I2C interface FPGA", meaning those signals are wired to FPGA fabric I/O, not to the dedicated HPS IOA/IOB pads. The published HPS baseline for this kit also does not connect an HPS I2C controller or a soft I2C master to those pins.
    Reference: Agilex™ 5 FPGA E-Series 065B Premium Development Kit User Guide, https://altera-fpga.github.io/latest/embedded-designs/agilex-5/e-series/premium-065b/gsrd/ug-gsrd-agx5e-premium-065b/
    <ANS> In Quartus Prime:
    1. Search the QSF or Pin Planner for FPGA_3V3_SDA and FPGA_3V3_SCL. No location assignment means nothing in that project drives the bus.
    2. In Platform Designer, open the HPS Pin Mux tab. If I2C0 or I2C1 is set to FPGA, follow i2c0_sda_i, i2c0_sda_oe, i2c0_scl_in_clk, and i2c0_clk_clk (or the I2C1 equivalents) to the top-level ports. Those conduits tied to the Bank 5A pins mean the HPS I2C controller is the master.
    3. If a soft I2C IP has its SDA and SCL ports connected to those same pins, that IP is the master.
    In Linux, on the board booted from that image, run i2cdetect -l. An enabled HPS I2C controller shows up as a DesignWare adapter (i2c_designware). A soft master shows up only when that fabric IP and its device-tree node are in the image. However, on the enablement baseline, neither adapter is attached to FPGA_3V3_SCL/FPGA_3V3_SDA.
    Thank you.
  • ai_responder's avatar
    ai_responder
    Icon for Community Manager rankCommunity Manager
    Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
