Agilex 5: Altera ace5lite CCT CSR
- 1 year ago
This reference design with Cache Coherency Translator (CCT) Intel® FPGA IP is for the Agilex-7 device.
Altera ACE5-Lite Cache Coherency Translator (CCT) FPGA IP is allowing any AXI-4 Manager to communicate with FPGA-to-HPS ACE5-Lite interface in Agilex™ 5 SoC devices and embed the cacheability and coherency signals to the ACE5-Lite subordinate of HPS.
https://www.intel.com/content/www/us/en/docs/programmable/683130/25-1/use-case-73029.html
Cache Coherency Translator (CCT) Intel® FPGA IP is allowing any AXI-4 Manager to communicate with FPGA-to-HPS ACE-Lite interface in Stratix® 10 or Agilex™ 7 SoC devices and embed the cacheability and coherency settings to the ACE-Lite subordinate of HPS.
https://www.intel.com/content/www/us/en/docs/programmable/683130/25-1/use-case-22704.html
Tiwari
Let me check again with the custom design project. Will confirm on this again.
But, this IP I can see in the example design-https://altera-fpga.github.io/rel-25.1/embedded-designs/agilex-7/f-series/soc/setup-use-bridges/ug-setup-use-bridges-agx7f-soc/#build-hardware-design
Tiwari
It may also be because I am using the Agilex 5 (A5ED065BB32AE4SR0) - what do you think?
