Agilex 5 - PCIe
When I initially saw in your documentation that there was information about changing the BIOS setting from “AUTO” to the appropriate standard, I changed it immediately, but unfortunately I got the same error.
Unfortunately, I’ve had a problem with the DevKit (MK-A5E065BB32AES1) right from the start—I even started a thread on the forum about it:
And from the Arrow distributor, I received their startup kit:
I’m currently working on that one.
I’ll try to check it on a different host as well. By the way, do you have any Windows drivers?
- Wincent_Altera1 year ago
Hi Robert,
Sorry, I miss out your reply in 1Apr, If linux, we do have BUT, not in window version ..Perhaps you can try to install both window and Linux at the same place (that is what I try in the when drafting the document)
Another things you could try is, try to toggle all Hardware DIP switch back to its default position, this help most of the time to link up (based on my experience)
Wincent_Altera
