Agilex 3 AVST programming fails
- 1 year ago
I noticed that the nStatus drops to a low value for a short time, which indicates that something is wrong with the data. I fixed the problem and the programming is working.
Samuel
Can you try higher frequency for AVST_CLK? 60kHz is too slow. Can start from 1MHz.
You can also keep AVST_VALID -> high during streaming, even after AVST_READY goes low.
Only send the idle clock cycles after AVST_READY goes low, with AVST_VALID = 0.
Please check signal condition with oscilloscope, is it clean or too noisy.
regards,
Farabi
- sl2421 year ago
Hi Farabi,
>60kHz is too slow
Is there a time out or something?
Unfortunately, we cannot increase the speed without further effort. We first need to implement a Linux driver to optimize access to the SPI interface and the pins. I will get back to you in a few weeks. If you have any further ideas, please let me know.
Samuel
