ILYA_SF's avatar
ILYA_SF
2 years ago
Agelix 5 IBIS AMI Models
I"ve downloaded the IBIS models and need run board sims for Agelix 5 board. I need to run DDR4 wizzard in Hyperlynx with AMI or non AMI model (I've tried HSIO_IBIS_AMI and HSIO_IBIS model), both generate the error in Hyperlynx 2.10. Just for curiosity.
I've tried to use any I/O using the AMI model (just to see if model is working) with the odb++ layout files and was not able to either. It generates Error message like below.
"Warning Pin XX of component Intel_Agelix_5_Device has no model in the file HSIO_IBIS_AMI.ibs.
Or pin XX type differ (e.g POWER pin found where I/O pin required."
  • AdzimZM_Altera's avatar
    AdzimZM_Altera
    Hi
    I think you can try to download the IBIS model again to make sure the file is not corrupted.
    Make sure you choose the correct buffer in the configuration and the buffer is used the model from the specific .ibs file.
    You also can check the IBIS model from different device to see if the software is working well.
    Adzim
    AdzimZM_Altera
    As we do not receive any response from you on the previous reply that we have provided, I now transition this thread to community support. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
