ILYA_SF
2 years agoAgelix 5 IBIS AMI Models
I"ve downloaded the IBIS models and need run board sims for Agelix 5 board. I need to run DDR4 wizzard in Hyperlynx with AMI or non AMI model (I've tried HSIO_IBIS_AMI and HSIO_IBIS model), both gen...
AdzimZM_Altera
2 years agoHi
I think you can try to download the IBIS model again to make sure the file is not corrupted.
Make sure you choose the correct buffer in the configuration and the buffer is used the model from the specific .ibs file.
You also can check the IBIS model from different device to see if the software is working well.
Adzim
