12 years agoAfter Power On, Devkit won't keep user image loaded and resets to factory image
Hi All, I have a Cyclone IV GX Dev Kit but I believe many of the kits are built the same way so the issue / solution may be applicable to others. The devkit has MAX II device which acts as...
12 years agoThanks - I finally received the same info from Altera this morning. It is a pity that this has been a known issue with V12.1 of the code but there is no errata on the dev kit webpage warning people about it.
For info, the reset after 2 seconds is caused by the PFL reset code at the bottom of max_c4gx.vhd of the MAX II code.
