JonWay_altera
5 years agoHi @Shirley
Check how many channels are you measuring? The more the channels the lesser the sampling rate. Check using just 1 channel, disable the others.
Shirley
5 years agoHi JonWay, many thanks for your reply. I forgot to mention that I had figured out how to set a higher sampling rate. Changing the tHCONVST parameter in adc_ltc2308.v to a smaller value will increase the sampling rate. It's associated with the operation of ltc2308. The default value of tHCONVST is to set a sampling rate of 100ksps.
- JonWay_altera5 years ago
Thank you very much for your sharing. I'm sure this will be helpful to others who faces the same issue. Meanwhile, I will set this thread to closed.
