Shirley
6 years ago[ADC-SoC] Low sampling rate of ADC LTC2308 on the ADC-SoC board
I have a Cyclone V SoC high-speed ADC Development Kit (ADC-SoC) from Terasic Inc. It uses ADC LTC2308 from Linear Technology. Both the ADC-SoC manual and the datasheet of LTC2308 says it has a sampli...
JonWay_altera
6 years agoHi @Shirley
Check how many channels are you measuring? The more the channels the lesser the sampling rate. Check using just 1 channel, disable the others.
- Shirley6 years ago
Hi JonWay, many thanks for your reply. I forgot to mention that I had figured out how to set a higher sampling rate. Changing the tHCONVST parameter in adc_ltc2308.v to a smaller value will increase the sampling rate. It's associated with the operation of ltc2308. The default value of tHCONVST is to set a sampling rate of 100ksps.
- JonWay_altera6 years ago
Thank you very much for your sharing. I'm sure this will be helpful to others who faces the same issue. Meanwhile, I will set this thread to closed.
