15 years agoADC Cyclone III Dev. Kit
I'm using the ADC Port A on the HSMC Mezzanine Card. The ADC is the AD9254. I want to control the sample rate. After reading the data sheet I'm still not sure how this is possible.
It says the CLK+ and CLK- are the clock input signals for the AD9254 and that sample rates can varie between 10 and 150 MSPS. There is a data output clock, the DCO, which determines the speed in which the data comes out of the chip. Can I change the speed of the DCO? What is the speed of the DCO? thx!1 Reply
have the same problem too. i'm new user of fpga. and using vhdl codes. i can use dac block but it's output range between -220 mV and 448mV is it normal ? and how can i send dac outputs to adc's input, or have can i programme dsp builder's adc converter?
