15 years agoADC Cyclone III Dev. Kit
I'm using the ADC Port A on the HSMC Mezzanine Card. The ADC is the AD9254. I want to control the sample rate. After reading the data sheet I'm still not sure how this is possible. It says the CLK...
15 years agohave the same problem too. i'm new user of fpga. and using vhdl codes. i can use dac block but it's output range between -220 mV and 448mV is it normal ? and how can i send dac outputs to adc's input, or have can i programme dsp builder's adc converter?
