Access to System MAX design for Agilex 5 kit
- 5 months ago
Hi cblixt1
After further checking internally, unfortunately, System MAX10 design will be not available as part of the installer package for this development kit.
Aqid
I am referring to the engineering sample version, the only one available for ordering as of yet: Agilex™ 5 FPGA and SoC E-Series Premium Development Kit (ES)
I'm assuming there will be an installer package for the -A version when it is ready. Will that include the System MAX design?
I really apologize for the inconvenience.
You can use the BTS GUI for temperature monitoring.
Refer here: https://docs.altera.com/r/docs/814550/current/agilextm-5-fpga-e-series-065b-premium-development-kit-user-guide/temperature-monitor
- cblixt14 months ago
Thank you. Yes, I know I can do that. But what if I want to make temperature readings available to the main FPGA on the board, using existing connections? I've already successfully done that on the Agilex 7 kit, but it requires access to the system MAX project or a full rewrite of that. The latter seems like a waste of time.
I realize there is nothing to do about this, so I will mark this as solved, but I fail to see the logic in providing this design for one kit but not for another.
