Access DDR3 RAM from Linux program on HPS
Helo,
May I know which DDR3 RAM are you referring to? Is it on the HPS side or the FPGA side?
Correct me if I am wrong, you want to receive data from Ethernet to HPS DDR3 or via HPS, then send the data to be stored in FPGA's memory?
- Sperber6 years ago
Hi Berlazare_I_Intel,
thank you for your answer.
I want to address the external DDR3 memory (1GB), build in in the Terasic DE10-nano Board.
In the user manual of this evaluation board it is written, that it is connected to the dedicated Hard Memory Controller for the HPS.
So I guess my question better should be: How can I work with the Hard memory controller of the HPS from a C++ application running on Linux on the ARM Processor.
My C++ application received data over ethernet which I want to store in the external DDR memory of the DE10-nano board.
I don't want to use the FPGA fabric right now. The application is running on the linux distribution on the ARM processor of the HPS.
In the meantime I found an example how to write data into the DDR3 memory from Preloader on page 33 of the following document:
In this example data is just written to a memory space starting at the address 0x100000 .
long *base= 0x100000;
addr = base + cnt; /* pointer arith! */
sync ();
*addr = data_temp[i];
Is this what I need to do?
Do I have to map the memory somehow before I can use it?
Where is written that the base address is 0x100000 ?
I had a look into the Cyclone V HPS Memory Map (https://www.intel.com/content/www/us/en/programmable/hps/cyclone-v/hps.html#topic/sfo1418687413697.html) but I didn't find the address 0x100000
Thank you very much.
Best regards
Johann
- EBERLAZARE_I_Intel5 years ago
You may find the information in our Cyclone V SoC HPS TRM section here:
The address 0x1000000 is by default, MPU accesses to locations between 0x100000 (1 MB) to 0xC0000000 (3 GB) which is made to the SDRAM controller.
