14 years agoAbout storing a rom_init.mif file on ROM module in Sopc system
Hi, I designed a custom component in Sopc builder to insert in a Nios system...my custom component is based on a Rom memory that during simulation I loaded with a file.mif using the megawizard too...
14 years agoHow did you infer your memory in your custom component? If you used an altera memory component, then you can use a parameter to control what file to use to init the contents.
Have a look at the recommended hdl coding styles (www.altera.com/literature/hb/qts/qts_qii51007.pdf) pages 11-33 and over. Alternatively you can also use code generated by the megawizard.
