About skew method for source synchronous input constrains in AN433?
Hi Sir, I understand your concern. However, usually the skew between data in and input clock is small and can be ignore. Unless it is critical in your board design and you are seeing the big skew between data and clock. With this you can manually change the - wafeform value for the input clock create clock command to compensate the board skew.
create_clock -name input_clock -period 10 -waveform { 2.5 7.5 } [get_ports clk_in]
- Lambert6 years ago
Hi BCT_Intel,
If so, that makes me to make sure the trace fo the data and clk between device and FPGA have better to be the same length. And if the skew on the data pin and clk pin of the FPGA is very small, quartus will adjust the trace delay between clk and data to satisfy the timing according the skew information when edge-alignment and centre-aligned. In addition, I see that if I chose the method which puts the input clk to pll to generate sample clk by compensatory mode, in this method, the delay from data and clk pin to reg is almost the same, how quartus ii adjust the trace delay between data and clk to satisfy the timing?
Lambert
- BoonT_Intel6 years ago
In this case, you may use the set_input_delay to the data signal to compensate its skew relationship with clock in.
Hi BCT_Intel,
I have one more question, if the skew between data in and input clk is small and can be ignore, is there necessary for us to set constrains? It will be okay that we can only set the clock constarins (liking creat_clock -name input_clock -period 10 [get_ports clk_in])?
Lambert
It is ok as long as you have the set_input_delay as explain above
