About fpll recalibration failure problem of transceiver (simplex tx) under cyclone 10
Hi Lambert,
Thanks for your clarification. Based on your responses, there seems to be no issue with the clocks and your recalibration steps. Also, it seems like 2 boards are working but 1 is not. This seems to be something specific to the failing board. Just wonder if you have had a chance to check the following:
1. XCVR related power supplies to see if there is any anomaly with the failing board?
2. Have you got a chance to try with different fPLL to see if similar issue persists? Just to narrow down to specific fPLL only or all fPLLs are showing similar symptom in the failing board.
3. You might also want to use oscilloscope to check on the refclk eye diagram to see if there is any anomaly vs datasheet specs?
4. Just to check after refclk switching, if there is any other fPLL configuration that you are dynamically reconfiguring?
- lambert_yu5 years ago
Contributor
Hi CheePin,
Thanks for your suggetion, now I have found the root cause which is about the cal_busy signal, it's one async signal, the method I use this signal has problem.
Brs,
Lambert
