lambert_yu
Contributor
5 years agoAbout fpll recalibration failure problem of transceiver (simplex tx) under cyclone 10
I am facing one problem, which is about fpll recalibration failure on cyclone 10 board. Just for same .pof file, no timing violation and different cyclone 10 boards, after POR, the transceiv...
CheepinC_altera
5 years agoHi,
Please help to check if the RREF pins of your device are connected individually to 2k Ohm resistor to GND.
Chee Pin
- lambert_yu5 years ago
Contributor
Hi CheePin,
Just for your question, I make sure that 1,3,4 all are satisfy and for 2, step 1: get bus access; step 2: switch one reference clock to another reference clock; step 3: send recalibration command; step 4: release bus access; step 5: wait for the completion of recalibration.
For another thing, I try 3 boards(all same, except fpga chip), 2 boards work normally, and another usually has this problem.
Brs,
Lambert
Contributor
+fpga chip : 10cx150yu484e6g
software : quartus 17.1
