Jos
6 years agoA pof-file read out from a MAX10 development board does not run on another one.
I have a MAX10 development board Rev. C (1) with a functioning
application. I would like to run it on a second, similar one (2).
So I read the pof-file with the programmer from (1), by using the ...
NurAiman_M_Intel
6 years agoHi,
Apologize for the delay in response as i was on leave.
I have shared LED blinking sof file through forum email.
Aiman
Jos
6 years agoThank for your sof-file. Before I tested it we found the source of the problem and solved it.
I use NIOS, which tries to read the MAC address from the flash. This has no success with freshly programmed boards. So therefore the TCP connection is refused, which is the only error visible to the application program.
The solution is to connect to NIOS from ECLIPSE. NIOS asks (visibly) for a code via the JTAG UART. As soon as that is provided a MAC address is stored. From that moment on NIOS/TCP functions o.k.
