A pof-file read out from a MAX10 development board does not run on another one.
Apologize for the delay in response.
After looking into your feedback and checking with our internal team, since the LED flashes from both board A and B, there should be no problem with your device. LED flashes means your configuration is working. However, may i know what do you mean by TCP/IP not functioning? Are you using IP/protocol that is dependent on device? Some IP/protocol can only be use on specific/multiple devices.
Aiman
- Jos6 years ago
Dear Aiman,
Thanks for your reply. I am a bit late because
of a vacation.
I agree with your remark about the flashing LED.
I use a C program running on NIOS that uses
the TCP/IP stack from an example. When the FPGA
is started it waits for a TCP/IP connection. This
connection is initiated by a program on a laptop.
What I mean by TCP/IP not functioning is that
the laptop issues an error message, because it cannot
establish a connection.
The TCP/IP stack/protocol functions on one
MAX10 board, while it does not on another,
of the same model. This is strange. I doubt if this is
really a problem with the stack.
Jos
