A pof-file read out from a MAX10 development board does not run on another one.
Dear Aiman,
Thanks for your reply. Mine is late because of a vacation.
Point wise:
1. I thought of doing this, but I did not do it because I was afraid
to be left with a board/firmware that does not work anymore.
And I need it for our radar.
2. The old and new .pof differ a bit at the start and the end.
3. OPN= 10M50DAF484C6GES
Jos
Some additional information:
I accidentally programmed the working board A with the
pof-file read from it previously. The board A was still working.
I programmed the pof-file of board A into the new
board B and 'examined' it. The resulting pof-file of
B and the one of A were identical. Nevertheless,
board B did not work with the radar.
As a final check I 'examined' boards A and B and compared
the pof-files: they were identical.
So board A and B have the same firmware but only A functions.
By the way: I used the auto detect result: 10M50DA.
Jos
- Jos6 years ago
Some more information: the design includes a flashing LED.
On both board A and B the LED flashes. So part of the design
runs on B. The trouble starts with TCP/IP not functioning.
Jos
- NurAiman_M_Intel6 years ago
Thanks for your reply. I am checking this with my internal team and will let you know once i got the answer.
Thanks for your understanding.
Aiman
