A pof-file read out from a MAX10 development board does not run on another one.
Kindly try below suggestion and let me know your feedback.
- Program the examine .pof again on board A. Is it working?
2. After program the .pof file in board B, try to examine again. Also, try to compare old .pof and new .pof.
3. What is the OPN number that is used for board A and B?
Let me know your feedback.
Aiman
- Jos6 years ago
Dear Aiman,
Thanks for your reply. Mine is late because of a vacation.
Point wise:
1. I thought of doing this, but I did not do it because I was afraid
to be left with a board/firmware that does not work anymore.
And I need it for our radar.
2. The old and new .pof differ a bit at the start and the end.
3. OPN= 10M50DAF484C6GES
Jos
- Jos6 years ago
Some additional information:
I accidentally programmed the working board A with the
pof-file read from it previously. The board A was still working.
I programmed the pof-file of board A into the new
board B and 'examined' it. The resulting pof-file of
B and the one of A were identical. Nevertheless,
board B did not work with the radar.
As a final check I 'examined' boards A and B and compared
the pof-files: they were identical.
So board A and B have the same firmware but only A functions.
By the way: I used the auto detect result: 10M50DA.
Jos
- Jos6 years ago
Some more information: the design includes a flashing LED.
On both board A and B the LED flashes. So part of the design
runs on B. The trouble starts with TCP/IP not functioning.
Jos
