MLaus3
6 years ago8192-point FFT with Intel FFT IP Core
Dear Intel Support Community, I am writing my bachelor thesis in electrical engineering at Vector Informatik GmbH at the moment. My target is to develop a cheap spectrum analyzer using the Fast Fo...
MLaus3
6 years agoHi,
thank you for your information so far, I really appreciate that!
I found an Eval Board (DE10 from Terasic with Intel Cyclone® V SE 5CSXFC6D6F31C6N device) which could fit for my requirements:
• Dual-core ARM Cortex-A9 (HPS)
• 110K programmable logic elements
• 5,761 Kbits embedded memory
• 6 fractional PLLs
I think it has enough resources and LEs.
Do you think that it is possible to do the 8192-FFT on this board?
Thank you in advance,
Best regards
Max
CheepinC_altera
6 years agoHi Max,
By merely based on the existing resource utilization table in the user guide, there should be no issue to implement the 8192 point FFT with the CV device. However, I would recommend you to create simple test design with the same CV device and run through Fitter compilation to verify this.
Chee Pin
