5GNR FEC PCI device not shown from lspci
- 5 years ago
The image is not provided with the acceleration stack. Can you check with your local FAE? Thanks.
Correction: you must install the Acceleration Stack in order to run those commands. It is not a "if", it is a MUST. You can either install the RTE or the Development version.
Hi Jon,
Thanks again, yes I have the acceleration stack installed, where can I find the FEC image?
BR
Sean
- SeanMa5 years ago
any image under the following folder?
ls -lrt /usr/share/opae/n3000/super-rsu/2x2x25G/
total 44896
-rw-r--r--. 1 root root 1152 Nov 18 2019 VistaCreekBMCCSK0_CANCEL.bin
-rw-r--r--. 1 root root 1466 Nov 18 2019 super-rsu-2x2x25G.json
-rw-r--r--. 1 root root 45089792 Nov 18 2019 sr_vista_rot_2x2x25g_19ww43.6_unsigned.bin
-rw-r--r--. 1 root root 869632 Nov 18 2019 bmc_fw_vista_rot_revd_19ww46.5_signed.bin- JonWay_altera5 years ago
