5GNR FEC PCI device not shown from lspci
- 5 years ago
The image is not provided with the acceleration stack. Can you check with your local FAE? Thanks.
additional info if it helps:
lspci -vd8086:0b32
b7:00.0 Processing accelerators: Intel Corporation Device 0b32
Subsystem: Intel Corporation Device 0000
Flags: bus master, fast devsel, latency 0, IRQ 255, NUMA node 1
Memory at e4d00000 (64-bit, prefetchable) [size=512K]
Memory at e4b00000 (64-bit, prefetchable) [size=1M]
Capabilities: [68] MSI-X: Enable- Count=7 Masked-
Capabilities: [78] Power Management version 3
Capabilities: [80] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [160] Alternative Routing-ID Interpretation (ARI)
Capabilities: [200] Single Root I/O Virtualization (SR-IOV)
Capabilities: [280] #19
lspci -vd8086:0b30
b3:00.0 Processing accelerators: Intel Corporation Device 0b30
Physical Slot: 9
Flags: bus master, fast devsel, latency 0, IRQ 36, NUMA node 1
Memory at e5000000 (64-bit, prefetchable) [size=512K]
Memory at e4e00000 (64-bit, prefetchable) [size=1M]
Capabilities: [68] MSI-X: Enable+ Count=7 Masked-
Kernel driver in use: intel-fpga-pci
Kernel modules: intel_fpga_pci
Hi @SeanMa
==> This is expected. Cards are shipped with the default DID 0b30/0b32 as you saw.
But according to https://doc.dpdk.org/guides/bbdevs/fpga_5gnr_fec.html it should have something with deviceID 0d8f Is there anything we missed?
==> You will only see 0d8f if you have programmed the 5GNR FEC image into the card.
- SeanMa5 years ago
Thanks for the answer, just wonder if there is any instruction for how to program FEC image into the card?
- JonWay_altera5 years ago
If you have installed the Acceleration Stack, and if you have the image, run below:
fpgasupdate <BIN filename> <BDF>
When it completed update...run
rsu bmcimg <BDF>
Example:
fpgasupdate example.bin 1a:00.0
rsu bmcimg 1a:00.0
Correction: you must install the Acceleration Stack in order to run those commands. It is not a "if", it is a MUST. You can either install the RTE or the Development version.
