DanielGP
5 years ago40Gbps Ethernet MACPHY IP Hardware Demo Design using QSFP
Hello!
I am trying to test the 40Gbps Demo for Stratix V in Quartus 18.1 Standard Edition. After compiling the project, I get the following error, even though the target device is right:
Error (1...
SengKok_L_Intel
5 years agoHi,
You can use the design as the starting point and then migrate/port over the design to the board that you intend to test.
Regards -SK
DanielGP
5 years agoHi, again!
Thank you for all the support. I am still struggling a bit here.
One question I need to be sure of. For the Stratix V GX Development Kit, we have a 40G QSFP connector that uses 4 transceiver channels. Is it really possible to use only one channel, i.e., having only one independent 10Gb connection?
I thought I could use this cable to have 1 to 4 independent channels but I cannot find any example to do that. Is it really possible?
Regards.
