DanielGP
5 years ago40Gbps Ethernet MACPHY IP Hardware Demo Design using QSFP
Hello!
I am trying to test the 40Gbps Demo for Stratix V in Quartus 18.1 Standard Edition. After compiling the project, I get the following error, even though the target device is right:
Error (1...
SengKok_L_Intel
5 years agoHi,
The protocol spec for 40G is not the same as 10G, which means, you can't use a single 40G Ethernet IP as four individual 10G ethernets. In this case, you should use two 10Gpbs IP.
Regards -SK
- DanielGP5 years ago
Ok, that was exactly my question, thanks.
In that case, I will not concern with the 40Gbps IP problem anymore.
Now, for the 10G, is there another example design for the stratix V development board I could follow? The one you posted above is for the Transceiver Signal Integrity Development Kit and I do not have that one (I even think this one is already discontinued), I have the Stratix V GX FPGA Development Kit.
Thanks once again!
