40Gbps Ethernet MACPHY IP Hardware Demo Design using QSFP
- Do you able to instantiate a new 40G/100G Ethernet Intel FPGA IP from the IP catalog?
- Do you able to create an empty project by selecting this device 5SGXEA7K2F40C2?
Regards -SK
- DanielGP5 years ago
1) Yes but only in a different project as you can check below:
2) Yes, I have already tested a few projects before. Recently, I tested the one with the your TSE IP and now I want to do the same but for 10Gbps Ethernet. Is there other option rather than this 40Gbps IP? What I need are two 10Gbps ethernet connections...
Thank you for the attention!
- SengKok_L_Intel5 years ago
If you can instantiate a new IP without a problem, then you can try to work around it by using the following settings to generate the 40G IP. If not, you might need to use v17.1std.
Thank you, I will give it a try!
Another issue, I have already read the User Guide but something is not clear to me yet. Can I use the 40Gbps IP to individually control each 10Gbps interface?
Basically for my project I need to control two independent 10 Gbps ethernet connections. I bought this adapter to have 4x10G SFP+ interfaces. Is it possible to have two 10Gbps connections with the 40Gbps IP or should I use two 10 Gbps IPs? Or this is not even possible at all?
Looking to the board pinout, I see there are 4 pair TX/RX, I assume one pair per interface. But then how do I manage the other ports (I2C, module signals, etc) separately?
Sorry for all the questions.
