40Gbps Ethernet MACPHY IP Hardware Demo Design using QSFP
Are you downloading the v17.1 design file, refer to the link below?
https://www.intel.com/content/dam/altera-www/global/en_US/uploads/1/1c/Alt_eth_40G_qsfp_171.zip
After unzipping the file, you can open the .qar in v18.1std. From the Project Navigator, select IP components, double click the “gen_40” to open the IP GUI, and then generate it (if you would like to upgrade to v18.1std).
It works well from my site. You may probably try it by using v17.1std as well.
Regards -SK
Hi, thank you for the fast reply.
Just to be sure, I downloaded again the example design from the link you provided (indeed, version 17.1, not 15.0 as announced in the tutorial page).
After opening the .qar in v18.1 and opening the gen_40 IP GUI, i am still not able to generate the IP as you can see below:
Is it a license issue? I have enabled the one-year license from recently acquiring the Stratix V Development Kit.
Thank you.
