12 years ago40-pin GPIO to Breadboard
Hello all,
Does anyone know a good way to connect the 40-pin GPIO sockets on the DE2-115 or SoCKit or HSMC/GPIO expansion card to a solderless breadboard? By good way I mean a way I can just order an appropriate part (Cable, connector, whatever) that will connect the board to the breadboard without having to create much if anything myself. Thanks! EDIT: See thread below for the solution.9 Replies
--- Quote Start --- Hello all, Does anyone know a good way to connect the 40-pin GPIO sockets on the DE2-115 or SoCKit or HSMC/GPIO expansion card to a solderless breadboard? By good way I mean a way I can just order an appropriate part (Cable, connector, whatever) that will connect the board to the breadboard without having to create much if anything myself. Thanks! --- Quote End --- Not sure If I am allowed to post sources, but this is what I am using with my DE-nano (while waiting for an DE1-SOC to be back in stock): http://www.technologicalarts.ca IDC Ribbon Cable-to-breadboard adapter 40-pin Part number: ADIDC40-M Benoit - Altera_Forum
somehow, my response to you never appeared.
I found a cie who does sell 40 pins IDC to bread board sockets That you can use with a 40 pins flat cable. I use this with my DE NANO. I will post the info once this post appears (I am a new user)... Ben - Altera_Forum
The part I am using is:
ADIDC40-M Sold by technologicalart They do not sell the cable. I got the cable from eBay It'd you want the actual websites, send me a PM. Ben - Altera_Forum
Thank you! I cannot send PMs but I will google around for this. I appreciate the pointer.
--- Quote Start --- Thank you! I cannot send PMs but I will google around for this. I appreciate the pointer. --- Quote End --- Ok, Here is the link.... http://www.technologicalarts.ca/shop/store/details/250/56/adapters/ribbon-cable/idc-ribbon-cable-to-breadboard-adapter,-40-pin.html There must be other vendors too.. Benoit - Altera_Forum
Just tried to post the direct url, no joy
But just a Google search should do the trick. There must be other sources to. But I could not find one for 40 pins Spammers are poisoning forums, as it drives moderators to become Extremely cautious.... Ben - Altera_Forum
Found it. Ordered several. Great pointer. Shame the moderator won't allow a link because I looked for days before posting and giving up and you had exactly the right thing. Thanks again!
Glad it solved your issue.
Maybe you should edit your initial post and mark this thread as [SOLVED] Ben - Altera_Forum
Did that. Thanks for the suggestion.
