BAmar1
6 years ago25G debug on Stratix10 MX h-tile
I am try to test 1 lane 25G by PRBS test. I build sample design in "25G Ethernet intel FPGA IP" . when I run Transciver Toolkits I am always get "couldn't grab setting for channel TX./RX . I add o...
BAmar1
6 years agoYes, the "Transceiver Toolkit" is stuck and need to "end task" to exit from the tool . its need to reload again the image to FPGA for connection to transceivers correctly .
Other issue :1. the transmit PRBS is inverted and no doc described that its correct ? 2. the partner not detect link up when PRBS is OFF what the reason ?
