BAmar1
6 years ago25G debug on Stratix10 MX h-tile
I am try to test 1 lane 25G by PRBS test. I build sample design in "25G Ethernet intel FPGA IP" . when I run Transciver Toolkits I am always get "couldn't grab setting for channel TX./RX . I add o...
SengKok_L_Intel
6 years agoHi,
It seems like there are some dependencies. Do you mean the toolkit will be stuck if you disconnect the port/disable sending data from the partner? Does this helpful if reset the IP? Can it back to normal if you reopen the ToolKit again with proper connection?
Regards -SK
