BAmar1
6 years ago25G debug on Stratix10 MX h-tile
I am try to test 1 lane 25G by PRBS test. I build sample design in "25G Ethernet intel FPGA IP" . when I run Transciver Toolkits I am always get "couldn't grab setting for channel TX./RX . I add o...
SengKok_L_Intel
6 years agoHi,
Before use transceiver toolkits, does the example design working as per the link below? This can help to ensure if the clock frequency is all running fine.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-dex-s10-25gbe.pdf
Did you enabled the "Native PHY Debug Master Endpoint"?
Regards -SK
