NZhan1
6 years ago1G/10GbE IP works on 1G/10G mode with auto-negotiation turned off
Hi, Could you help to give some advices? There are two 1G/10GbE phys with 1G/10G and RX+TX mode in A10GX, connected with only one fiber, that is: one PHY works on TX only, and the other one work...
NZhan1
6 years agoHi Chee,
Thanks. We will try.
These two issues are all in the same project, but not related.
This issue is caused by fiber re plug.
That issue is caused by recompilation.
Thanks for all your supports!
Nicole
CheepinC_altera
6 years agoThanks lot. By the way, would you mind to share the .qsys file of your 1G/10G IP? I seems could not locate in the case. Thank you.
Chee Pin
