13 years ago12V instead of 9V PowerSupply for Nios Stratix Edition?
Hi, I've an old Nios DevKit (StratixEd, EP1S10). The UG says, I've to use a 9V PowerSupply, but due to the lack of 9V-Supply I want to know if it's possible to use a 12V Supply? On Bo...
13 years agoThanks for your post.
The LDO's abs max is 45V, operation range is 8V to 40V, so 12V should be no problem. I'm only affraid that the schematics shows not all 9V-Connections. And btw, some ExtBoards for the prototype connectors (SantaCruz-Connector) want 12V. Is this standard?
