10m50 development board SDRAM implementing.
- 6 years ago
Upon checking in design store, there is a Intel MAX 10 FPGA Development Kit with DDR3 UniPHY tutorial:
https://fpgacloud.intel.com/devstore/platform/15.0/Standard/design-example-max10-10-ddr3-300mhz-uniphy-half-rate-x24/
But I found that the project build in Quartus Prime v15.0 version, it might be some IP not compatible to use in Quartus Prime Lite v18.1.
You can try to download and look into the design.
There are some tutorials for Intel MAX 10 Development Kit DDR3:
https://fpgacloud.intel.com/devstore/?page=1&search=ddr3
For more information in MAX 10 External Memory Interface, you may need to refer the document as below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_emi.pdf
I am using Intel MAX 10 FPGA Development Kit which has dual ethernet port.
And i am using Quartus Prime 18.1 lite edition with NIOS II eclipse Mars.2 version 4.5.2
is there any tutorial or example for adding sdram on this development kit?
can i add sdram with lite edition quartus?
And which IP core do I need to use for communication with sdram, sdram controller or ddr3 sdram controller with UNIPHY?
Thank you for your support!
