JRe2s
1 year ago10M02SCE144I7G with 192MHz clock frequency
Dear team, we have a RS485 communication application running between 2 FPGA boards. FPGA1 sends a ditital bit stream with 12MBit/s through a RS485 trancseiver to the RS485 transceiver of board 2 wh...
- 1 year ago
Is there any further question on this?
sstrell
1 year agoYou also require I/O timing constraints: set_input_delay and set_output_delay that specify the maximum and minimum external delays to meet setup and hold timing requirements at the FPGA (inputs) and at the downstream device (outputs).
