10M02SCE144I7G programming through USB blasters fails
- 1 year ago
Since you have solved your issues, I’ll transition this thread to community support. If you have any new questions, feel free to open a new thread to receive assistance from Intel experts. Otherwise, the community members will continue to help you here.
Thank you for your engagement!
Fakhrul
Hi JRe2s,
Yes, when programming a MAX 10 FPGA, you typically need to first program the "SOF" file, which essentially acts as a bootloader that allows you to then program the full configuration data onto the device using the on-chip flash memory. Check the Intel® MAX® 10 FPGA Configuration User Guide for more details. Additionally, when you enable this real-time ISP, it is a slow mode. In certain situation, we would suggest to enable it as a workaround to overcome the error.
Fakhrul
