10M02SCE144I7G can be programmed with pof file but doesn't work.
- 6 years ago
Hi hyang73,
From your schematic, you CONF_DONE pin is leave unconnected. The CONF_DONE pin should be pulled high.
MAX 10 will not enter the initialization and user mode if the CONF_DONE pin is pulled low.
And one more thing, you can try to TICK/UNTICK "Enable real-time ISP...." in Quartus programmer. Try it out if any improvement for your MAX 10 device.
Hi hyang73,
yes this is the route cause of this failure issue. thank you very much! :)))))))))))))))))))
