10M02SCE144I7G can be programmed with pof file but doesn't work.
- 6 years ago
Hi hyang73,
From your schematic, you CONF_DONE pin is leave unconnected. The CONF_DONE pin should be pulled high.
MAX 10 will not enter the initialization and user mode if the CONF_DONE pin is pulled low.
And one more thing, you can try to TICK/UNTICK "Enable real-time ISP...." in Quartus programmer. Try it out if any improvement for your MAX 10 device.
Hi hyang73,
- hyang736 years ago
yes this is the route cause of this failure issue. thank you very much! :)))))))))))))))))))
