13 years ago1.8V I/O for DDR Controller? (BeMicro SDK MDDR)
The BeMicro SDK designs come with a Microtronix MDDR controller evaluation core. They use the 1.8V I/O standard, which allows them to use the thresh pin on the bank as the CS pin of the DDR. Wh...
13 years ago --- Quote Start --- Whenever I try to use another DDR controller, the 1.8V I/O standard causes a fitter error. --- Quote End --- There is more differences between regular DDR and mobile LPDDR than just the I/O standard. This Micron note describes some of the issues, but long story short: just changing the I/O standard isn't going to result in a usable system. http://www.micron.com/~/media/documents/products/technical%20note/dram/tn4615.pdf
