DLiu5
5 years ago更新dtb以后SD卡boot卡住了!提示:Waiting for root device /dev/mmc
1. 我将DE10-Nano的 GHRD 工程基础上 增加了一个UART(RS-232 Serial Port) IP。 2. 修改top文件,增加串口的input和output 端口,并在例化里面新增了串口。 3. 综合后在pin planner里面将串口的端口接到了GPIO0的 IO上。 4. 生成rbf和dtb (hps_common_board_info.xml 、 soc_sys...
EBERLAZARE_I_Intel
5 years agoHi,
You cannot use two different device tree for the same design that has connection with HPS, you need to use the same device tree that was compiled from the original design.
DLiu5
5 years agoThanks for reply!
I did use the same Quartus project with same Quartus and EDS version.
- EBERLAZARE_I_Intel5 years ago
Yes, but you cannot use different new DTB into the SD Card.
Any follow-up from your side?
