Dr_FPGA's avatar
Dr_FPGA
6 years ago
X2go timing out local host connection
I am following similar instructions as in this thread:
https://community.intel.com/t5/Intel-High-Level-Design/X2GO-client-connection-failure-Socket-Disconnected/m-p/656069#M209
However in my case X2go connection to localhost times out. Please see the attached picture.
I am able to connect to devcloud with PuTTY in terminal mode. AWS and NIMBIX GUI work fine in my environment.
I already dropped all firewalls: soft and on the router, still the same result. Please advise what the next step.
Thank you.
  • Which compute node are attempting to run X2Go on? You can check X2Go status with systemctl status x2goserver. Did you run the tunneling command from your local (PC) terminal, not the login-2 node? X2go doesn't run on all nodes. Best of luck, if you are still stuck, send me a few times for a quick conference call.
    Cheers
    Larry
  • Lawrence_L_Intel's avatar
    Lawrence_L_Intel
    Cheers
    Larry
      • BoonBengT_Altera's avatar
        BoonBengT_Altera
        Icon for Moderator rankModerator
        Hi @Dr_FPGA,
        Hope this message find you well and good to know that it is working now, we would be closing the thread. If you have further queries, Please do post a response in the next 15 days.
        After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
        Warm Regards
