X2go timing out local host connection
- 6 years ago
Which compute node are attempting to run X2Go on? You can check X2Go status with systemctl status x2goserver. Did you run the tunneling command from your local (PC) terminal, not the login-2 node? X2go doesn't run on all nodes. Best of luck, if you are still stuck, send me a few times for a quick conference call.
Cheers
Larry
Hi Lawrence,
I missed the second terminal ssh command. After I followed exact instructions in section 6.0
https://github.com/intel/FPGA-Devcloud/tree/master/main/Devcloud_Access_Instructions
I was able to connect with X2Go in GUI mode.
Thank you.
Hi @Dr_FPGA,
Hope this message find you well and good to know that it is working now, we would be closing the thread. If you have further queries, Please do post a response in the next 15 days.
After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Warm Regards
