wrong results for implementation logic gate
- 3 years ago
Very likely because the pushbutton inputs are active low and not active high.
So when you push the button, the FPGA input sees a LOW value.
When the button is not pushed, it defaults to a HIGH value.
Schematically, the pushbutton is connected to GROUND and the FPGA input, which has a pullup to VCC to set the unpushed state.An active low logic AND function becomes an active high logic OR function, and vice versa.
So simple fix is to invert the sense of the input from each pushbutton (add a NOT function).
Most likely your LED output is active HIGH (meaning when the output is high the LED is ON) but it could be inverted as well.
You may or may not need to add a NOT to the output LED driver, so when the output is HIGH the LED is ON.
It depends upon the design of your board.
I’m glad that your question has been addressed, for now I will set this case to Close-Pending.
Nazrul Naim
