writing and reading max10 ufm
hii i have the neek dev kit , and i did a project to write and read the max10 ufm
i see in the signal tap in my project that i can write the data and read successfully
i programmed the board with the pof so that my firmware is inside the board , but when i turn off the board and turn it on again , and read the data from ufm i see that the data is all zeros meaning that the data didn't get saved in the ufm , and i know that the ufm is non volatile memory .
i am using the on chip flash ip , i expect the data to be saved in the ufm .
when i program the pof and perform the write and the do the read while the board under power everything is ok , data get written and read .
but the problem start when i turn the power down
do i need to do a special thing in order to commit the data to the ufm and save so i can read it after power up ???
- aiedb
hii thanks for help
i checked my state machine and i indeed did unintentional eraze of the ufm , i corrected my stm and its working fine
- WZ2
Hi there,
This is indeed quite unusual. UFM is a non-volatile memory, and in theory, its contents should not change or be erased unless explicitly commanded to do so. I suggest checking the UFM before power-down to confirm that the data is intact. Additionally, please ensure that no logic is accessing or modifying the UFM through the IP interface after the device powers up.
WZ
- FvM
I expect you are writing and reading UFM data through On-Chip Flash Intel FPGA IP Core? I don't see how it's possible to loose data after writing, presumed it's not unintentionally erased (to 0xff) or overwritten (to 0x00).- aiedb
hii yes i am using On-Chip Flash Intel FPGA IP Core
i will chick my code to see if there indeed the case of unintentionally erased (to 0xff) or overwritten (to 0x00).
