aiedb
1 year agowriting and reading max10 ufm
hii i have the neek dev kit , and i did a project to write and read the max10 ufm i see in the signal tap in my project that i can write the data and read successfully i programmed the board with...
WZ2
1 year agoHi there,
This is indeed quite unusual. UFM is a non-volatile memory, and in theory, its contents should not change or be erased unless explicitly commanded to do so. I suggest checking the UFM before power-down to confirm that the data is intact. Additionally, please ensure that no logic is accessing or modifying the UFM through the IP interface after the device powers up.
WZ
