Why don't support 100% traffic performance with N3000 PAC Board?
Thanks for your results and analysis!
We had the same problem with the board test for the N3000-1(8x10G) with spirent and N3000-2(2x2x25G) with IXIA, whcih is all traffic was received without loss in the speed of 99.99% and the traffic loss occurred in the speed of 100% .
We also connected ING-IN and EGR-OUT signals directly for output.
I have read your analysis and done signal tap capture on the 25G board card, and found that in the speed of 100% the ready signal would be '0' sometimes, and during this period there may be valid packets.
The difference with your results is that our pause_req signal is always '0'.
- SYeon5 years ago
Please check, an option for pause function when compiling.
If the Pause function is activated by this option,
In the loss environment will be lower than 99.99% by the pause function.
My test environment used 10GbE Link, so it may be a little different.
Also, to check the correct performance, i did the test after disconnecting the pause signal.
I couldn't find a solution for Loss in the Green area.
I explained the test results and finished the project with 99.99% performance.
My project manager understood that the cause of 99.99% of the performance was in the Blue area,
and I was able to close the project.
if there must be no loss , you can use the Pause function to prevent 100% transmission from the sender.
thanks
