SYeon
6 years agoWhy don't support 100% traffic performance with N3000 PAC Board?
I did a traffic performance test with N3000 PAC Board. but, the result of 100% performance were not confirmed. My test environment setup is as follows. 1. FPGA Source Version: Factory_Image in A...
JonWay_altera
6 years agoHi @SYeon Thank for the detail explanation of the issue.
The reason for packet loss is the you created a design that loops traffic directly from the Ethernet AVST interface AND is sending packets with minimum interframe gap. There is a rate difference between the Spirent Test Center Ethernet traffic generator and the N3000 internal clock. Because of this rate difference, there will be a small amount of packets dropped.
Setting the interframe gap to 13 bytes, will result in no packet drops.
